bj75 5spd implant from bj60....?
north bay, ontario
hi,
the factory 4spd has no vacuum assist on the H4 and i was contemplating of putting my bj60's 5spd for lower revs on the hwy which has the vacuum operated gizmo, is this doable? would the hump hole match up is the other question besides the speedometer cable gears......anything else i'm forgetting...maybe vacuum reserve canister?
tia,
ivanhoe
you will have a vacuum canister on the truck already.
you can use the t/case from a manual 5 speed and keep it manual shifting, up to you.
the VSV are a PITA and not cheap.
thx wayne for the heads up on the VSV. i gotta stop by to show you the latest toy:steer:(or is it money pit?:bang:) the shifter should fall into the same place?
