Okay, so about 2 weeks ago I notice my voltage dropping when I turn my truck on. But it only does this when its cold. If the engine is warm, or mildly warm its okay (ie. warm outside, or if its still warm from running). But what is weird is my batteries are normal voltage if I check them with a multimeter. I was thinking a bad ground. But I can see the ground on the side of the block and it looks good. It was wet and cold so I left it for a better day. Because as soon as the truck ran for about 20-30 seconds voltage would come up.
But something else weird started last night.
After I started my truck and the voltage came up the oil pressure shot up to 95% on the gauge at idle, and higher if the rpm goes up. What is with this? There should not be that kind of oil pressure in there. I am going to change my oil+filter in about 20 minutes just to make sure its not that. But I am thinking this is an electrical issue.
I am also going to check the ground.
Any ideas what is causing this?
I am sure what ever this is caused my electrical problems of a month ago.
Thanks,
Nick.
Thanks,
Nick.
