BJ60 vs FJ62 Instruments? (1 Viewer)
Michigan/Costa Rica
I want to replace the speedometer in my FJ62 with one that is calibrated in kph rather than mph. I've found one that came from a HJ60 but am unsure if it will fit (I'm in MI and the HJ60 is in OR). Does anyone know if they are interchangeable? Thanks in advance.
cruiser_guy
Good morning from here, Just finished updating ou
Wherever the truck stops!!
Website
wirrell.com
I'd bet they interchange but no guarantees.
Normandy Park Wa. ........now in San Diego Ca.
Be aware that if the Hj came from Canada it is 24v. but the connections are the same, you would just have to swap out the bulbs to 12v. I am running a FJ speedo in my HJ right now w/24v bulbs
Where are you in Costa Rica?
Pura Vida
Michigan/Costa Rica
Pura Vida
I just got back from two weeks in CR. This time we were mostly in the San Jose/Guanacaste area although home base is San Isidro de El General.
Regarding the speedo, the bulbs are not a problem. The FJ62 speedo has an integral VSS which I need to keep and I am concerned about the physical mounts. I understand that the FJ/HJ60 have a different dash than the FJ62.
Andy
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
Between B and HJ-60 there are no diferences .. but 62 are not common here in Panamá .. so I'm not sure .. but the gauge cluster5 looks very similar ..
Michigan/Costa Rica
Thanks for all your input. Sounds like it might work so I'll take a chance and buy the HJ speedo. Will post the results once I receive the unit.
