Hey Folks,
Ever since I did my body swap my rear heater does not have power. I'm sure I've just not plugged something in or something silly like that, but I've listed the truck for sale and this is one outstanding issue that I'd like to resolve for the next owner.
I do not have any power at the dash switch.
I do not have any power at the motor itself.
I've run 12v to the motor via a bypass and it runs fine.
I'm wondering if there is a relay somewhere for this unit.
The two large fuses in the fuse box (roundish) are functioning properly, one being for the front heater and the other for defrost.
The three pictures attached show:
1. Dash wiring:
- Left side of connector: Blue with black stripe, and two white with black striped wires, one being larger than the other.
2. Connector at floor heater:
- Two blue with black striped wires...large(ish).
3. Under Dash by fusebox:
- One white with black stripe wire going to ground under a 10mm bolt.
- One smaller white with black stripe wire hanging unplugged.
NOTE: It's this last smaller hanging white with black stripe wire that's not plugged in that I'm wondering about. I've looked everywhere under there for a home for it but have come up empty handed. I'm also not entirely certain if the larger white wire under the 10mm bolt is indeed a ground wire...it has an oem round end on it which gives the impression that it is for a ground.
Anyways, wondering if any of you have either a wiring diagram or can see something that I'm missing to make this work again.
Cheers!
1. Dash wiring:
Cheers!
