Hi all,
I have a 1982 BJ42 3B engine with this problem to gearbox : all gears work pretty good and is quiet,but the 5th gear jumps straight out as soon as you back off the pedal gas.....
furthermore :
- good clearance for shifter on the floor
- new bush on the bottom of the stick
- 2 locating pins in the housing are tight
but still jumps out of gear when I decelerate........
I also read in the forum
" is to place the 5th gear selector fork in the press and bend it by about 2 mm.. "
can someone help me ?
on which side should the gear slector fork be folded ?
do you have any advice to solve the problem ?
thank you
Giacomo
furthermore :
thank you
Giacomo
