Hi Diesel gang, I have just bought a 3B BJ42 LX and some issues I am resolving. Very low on power so I took it to a diesel fitter and he took a drive and thought it could be injectors and pump - the pump is original and he doesn't think the injectors have been done but the seller told me he had - so probably not!
anyway... Here is a bit from my purchasing review thread about where I am at with the 3B and some questions about where to from here:
Before commiting to a recon I started chatting to him about a diagnostic approach to see what could be done in the mean time. This is the outcome of that discussion.
1) I did an oil change. She bled 6.7l of very black oil and I replaced it with Fuchs Titan ultralube 15W40 diesel oil - she tool 6.5 and then another 2 or 3 hundred ml after the motor was turned over.
2) Replaced the oil filter : Z9
3) Replaced the air filter
4) Replaced the fuel filter z169a
Took her for a burl, immediately running a bit free'r - breating better and needed the oil change I reckon.
Once up the road I cracked the rack lock nut and opened her out just under 1/4 turn (counter Clockwise) and reseated the nut.
No black smoke and the power had definitely improved
Around the block and again another full 1/4 turn out - still no smoke and appreciable better depth in 1st and second.
I have eventually left it advanced 3/4 of a turn from where I started today and she is completely different to drive - still no smoke - idles well and does not need to be revved out to get some momentum going...
Questions:
1) How much should I go when gently making this adjustment - I know that I can damage the engine if I push it too far..
2) Will the injector, diaphragm, compression day of work be worth while or should I save my $$s for the clutch
Can I do this bit myself??
3) Can I get confirmation that the oil I selected is good - I am going to do a second change in 3000km and then only do it every 5-7k but that will give me a starting point.
4) What tyre pressure do people recommend - the handbook seems to suggest 24psi front and 28psi rear - I used to run 15 off road and 30 onroad allround for the Jeep... Any thoughts>
5) I filled her up with 50 L of diesel - are there any additives I should consider at this time to help clean the engine out or anything? It has an 85L tank - is there any point in completely draining it (carrying some fuel and doing a roadside prime/bleed) to ensure that it is all fresh or will that mean **** and gunk get into the motor?? I would like to confirm how much the tank capacity is and what sort of economy I am getting.
Thanks DieselMUD in advance,
Will
Questions:
Can I do this bit myself??3) Can I get confirmation that the oil I selected is good - I am going to do a second change in 3000km and then only do it every 5-7k but that will give me a starting point.
Will
