- Thread starter
- #21
Here's a pic of the interior firewall passenger side. As you can see there are 3 unattached connectors. In this view top right has 3 wires, 2 black, 1 red. Top left has 2 wires, 1 black, 1 black with yellow stripe, the lower connector has 2 wires, 1 black, 1 black with yellow stripe.
So obviously as Rudi pointed out earlier, my rig has been modified. I Googled PNs from ALT data plate, no results? Was thinking maybe someone had changed ALT to one with internal VR. As presently wired the ALT has a connector with 2 wires in chassis harness - 1 to key switch and other is ground. The larger gauge wire (which I assume is output) I believe is wired to the glow plug relay, which makes no sense.
To recap, I'm back where I started, battery not charging, and apparently non stock wiring, but it worked fine for 18 months. At idle ammeter reads slightly positive but pegs at 30A when RPMs increase. As expected voltage at battery increases as RPMs increase. When I first noticed the not charging issue I found blown ALT fuse in panel (2nd from bottom on my fuse panel). After replacing fuse I noticed increased ammeter reading, so I'm assuming something changed to elevate voltage/amps and consequently blew the fuse. I haven't run it extensively yet to see if fuse blows again. It starts and idles fine, I'm just leery of the high amp reading so I haven't driven it out of the shop driveway. Any insight would be appreciated as I obviously have no clue.
