Here is the story...
Starter motor was stuck ON (running all the time), and it pretty much wrecked the starter motor, and the fusible links. I have replaced the starter motor, replaced the fusible links, but now the NEW starter motor is still stuck in the ON (running all the time) position!
Things that have been checked...
1) ignition switch: fully disassembled, and inspected, it works like it is supposed to.
2) Starter Relay: works with 12V (didn't have two batteries to check it with 24V)
I have read that a bad ground can cause the starter to run all the time like this? Does any body have a solution from a similar problem?
I hope the wiring harness is not melted or something...
Thoughts?
Thoughts?
