Where does the passenger side headlight get its ground?
Does it get it from the dimmer relay some way? I was looking at the wiring diagram but can't make any sense of it
I have converted my system to 12 volts from 24 and this is the last bridge. The relay is 12 volts from the factory but I can only get the l/h headlight to power up. I have power at the r/h headlight when checking with a test lamp, it lights up on all three terminals.
high and low beam for the l/h side functions properly. I figured everything would function normally where it is 12 volts from the factory.
Thanks in advance,
Daryl
Thanks in advance,
Daryl
