I have this 1976 BJ40 that have a problem with air in the diesel system. While I was restoring it it was fine, but on first trip after putting the plates on it started to run uneven and then stopped. If I prime it, it runs for 5 minutes, then stop again. I thought I had found the problem in the return hose which I had overseen while restoring it. It was old and stiff, and I changed it. After that it was OK on one trip, then the problem started again. Now all hoses are new, all clamps have been checked, but still same thing. No trace of leakage.
I have read that somebody apply a pressure to the tank to provoke a leakage. I am afraid to do that. It is not much of a pressure that is needed to blow up the tank. So I plan to apply the pressure to the outlet pipe from the tank. Either with air, or just a hose to the ceiling filled with diesel. But how much pressure? I have been thinking 2 bar/ 30 PSI.
Any thoughts , anybody?
Other ideas?
Other ideas?
