After 6 years of resto I finally got the license plates on the car. And on the first test run the engine started to stall after a few kilometers. What a drag...
The engine has been fired up regularly during those years, and I have driven it some meters just to keep it alive. No problems with the engine.
It is pretty sure it is the feed pump because if I use the priming pump when it starts to run uneven it is good again at once.
Both the valves 22515 are new as the old ones had a tendency to get stuck. System is bled for air.
Any suggestion?
Any suggestion?
