lowenbrau
Max is right. There is only one oddball light (other than the headlights) which taps from between the batteries and that is the high beam indicator. The dashlight uses a resister on the side of the glovebox IIRC.
This is my 81 CDN BJ42.
There is a 24V bulb in there now (Thanks Greg!) as there wasn't one before. I'll put a volt meter on it this afternoon. The bulb goes brighter and right to 'off' when I turn my dimmer switch on the headlight knob.
Rob put a voltmeter on his light when back at the shop. Even though the housing says 12V, it was showing 23V or so if I am recalling correct. He'll confirm.
I have never replaced the dash pad light or the light for the heater, but according to that wiring diagram one of the headlights is powered from a battery tap and the other one from a tap on one phase of the alternator. However, since both headlights work without the engine running I am wondering if the wiring diagram is even correct?
The B phase?
21.3 volts with the bulb lit up. My truck should be CDN spec; I have the original warranty receipt from the Frontier Toyota dealership in Winnipeg. My original owner's manual doesn't list the bulb at all.
I just spent the last several minutes studying the wiring diagram in my 1980 FSM and it shows the LH headlight getting its power from the fusible link that taps off the RH (ground side) battery and the RH headlight getting its power from the B terminal of the alternator (which is connected to the LH (high side) battery positive 24V terminal) but the RH headlight is operating on 12V because its ground terminal is connected to the the same fusible link as the LH headlight power side. In other words, the LH headlight is drawing its power from the RH battery and the RH headlight is drawing its power from the LH battery.
That is really odd, i have 12V coming to this light.
We need to found out the electrical engineer of the time!
Wayne, here's a blast from the past: https://forum.ih8mud.com/diesel-tech-24-volts-systems/68379-78-bj-40-headlight-diagram.html
eleblanc, I'll be checking my 1981 BJ42 when it comes out of hibernation. Does not help you right now though.
My rig has 24v headlights. I guess I dodged that bullet by going JDM. I wonder if anyone has had resistors go bad and that my be the reason that you can run 24v dash bulbs now...
****e. Nope, totally forgot, and its back in hibernation now. Is it critical, or is this a spring project for you now?
gb
