I simply rotate the drive shaft till the flat spots on the birfield are verticle and then simply pull out.
I tried to pull the birfeilds and axles out of a fj62 axle housing.
I lined up the flat spots on the birfeilds with the verticle where the bearing sit in the axle housing.
They will not come out.
The only other factory i can think of is the axle housing is bent.
I 30 foot tree crushed the land cruiser and bent the axle housing at the some time.
Any advise on pulling the stuck birfeilds and axle shaft out would be great.
I'm about ready to start cuting on the axle housing.
Thank you for any help you can offer.
Brian
Brian
