Birfield damage *Pics*
austin, tx
I broke my passenger birfield in the mud :eek:
Wanted to show ya'll some pics and hopefully you can help figure out what this seal looking thing is and where it came from. I had to pull the 3rd member to get it out(it was inside axle housing). You can tell in the top picture it is too big to make it through the hole in the cavity. CruiserDan said there isn't suppose to be inside inside there like that, so where the hell did it come from?
austin, tx
Oh ya, I ordered two Longfields yesterday. I am going to make the driver side OEM birfield a spare. Anyways, here are some more pictures, let me know if you see anything that is a problem or needs to be repaired.
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
That is the centering ring that we talked about. The photo identifies it for me. At one time it was inside the housing out near the end. The flopping bits broke it loose. If you look on the opposite side you will see the other one. You have an expensive mess on your hands.
cruiserdan
Moderator
You are going to need an ABS front harness assembly. 04895-60060, list $530.04.....:eek:
You are also going to need an OEM birf to get the ABS ring. The aftermarket ones do not come with rings and the rings are not serviced seprately.
austin, tx
I think I have decided to go w/o abs. Seems like it will cost a 1000 or so to get it, with the harness and rings. I have been driving with out for about 3 months now.
I cannot get the spindle pics at the moment.
cruiseroutfit
Supporting Vendor
Moderator
Utah
Ouch!
Are you getting new inner axles from Long too? Your splines are fairly beat on the end, nothing some detailed filing won't fix, but be prepared both when removing the old star and installing the new birf.
austin, tx
cruiseroutfit said:
Ouch!
I will not be getting new inners from long or anyone at this point, looks like I got plenty of money to spend already :rolleyes: . Do they make inners for 80-series cruisers? I really need to to get by with what I have.
cruiserdan
Moderator
elmariachi said:
Can that centering ring be reinstalled/welded back in place? If not, how will he stab the shaft without scuffing up the new inner seal?
Semlin delt with that issue some tme back. He was able to reposition it. It's not clear to me if they are originally tacked in place or if they are a press fit.
cruiseroutfit
Supporting Vendor
Moderator
Utah
Lay the truck on its side, and let gravity do its work ;)
I know of alot of earlier axles that don't have the centering rings, they just have to be really careful and precise with the inner axle seal, and even at that, they run the risk of scuffing it up.
I think they are pressed in, as I have moved them before (its been a while, I can't recall 100% and that was on earlier Toy axles)
