Because the circlip on the end of the axle has to compress to fit between the spline, this job requires patience. It takes several or even many blows to compress the circlip. I clamp the axle in a vise vertically, then use a medium sized hammer and a brass drift to drive the spider off the shaft. It usually takes anywhere from 5-20 blows, not swinging particularly hard. Keeping a bit of tension on the spider helps. It really helps if you can visualize what's happening with the circlip. Each tap of the drift compresses the circlip a tiny bit, until it can finally fit in the slot and inside the splines. If the spider bounces back up between blows, the circlip expands again, which is why some tension helps- just press down with the brass drift constantly while tapping it with a hammer. I've heard of the circlip coming out in peices, I would attribute this to someone hitting it too hard- but if it works, great.
-Spike
