lx450landcruiser
Moderator
Ok all the info is on this board but it took some time to find all the tools and what not so i thought maybe ill just post a list of stuff i used and wouldnt wanna do with out for the job.
So......
Tools include
Brake cleaner (the more you get the faster the cleaning will go)
Mineral spirits (I would say at least a gallon)
A tooth brush is handy as is a wire brush (to get the crud off)
Lots of shop towels (Again the more you have the faster cleaning will go)
Plasitc sheets are nice as is card board (place it on the floor for dissesembly, then put a new sheet down for assembly. keeps things clean)
Brass hammer
Brass Drift (at least one)
Gasket or seal puller
Wood handle (for seating and driving in inner seal)
Fish scale (to test pre load)
54mm or 2 1/8 socekt (must be semi thin and deep as it has to fit in the hub and miss the stud)
Snap ring pliers
Flat head screw driver (Best to have one u dont care about that you can grind to a bit of a point, this way u can pop off the dust cap and also use it to pry parts apart)
Jack stands
Jack
Torq wrench (for specific torq ratings on assembly)
Wrench or rachet in sizes 10,12,14,17, 24 (I may be forgetting a few?)
Drain pan (for diff fluid)
Small pump (for replacement of diff fluid)
Small puddy knife (helps with the grease part)
Freezer (to freeze the races so they fall in easier)
At least 5 tubes of synthetic moly greese
Hose clamp (this is if you break the birf apart, u will use it to tighten the c clip to slid the birf back together)
Half a fence post with rag stuffed in one end (this is your birf breaking tool)
Can of black paint ( this is optional while ur in there cleaning things up shoot some coats over stuff so it wont rust)
I may or may not have missed some things so if you can think of anything please add here so people can simply look here.
good luck
mike
So......
Tools include
Brass hammer
Snap ring pliers
Jack stands
Jack
good luck
mike
