Bilstein 5100 question
Reading, MA
I am about to buy shocks. I have a 2.5" Hell Creek suspension and MAF anti-inversion shackles. Should I order the shocks for the 2" or 4" suspension lift?
Sent from my iPad using IH8MUD
That would depend on how long the shackles are. I have 2.5" springs on mine but when I put longer shackles on it 7-8 years ago the shocks were seriously limiting down travel and I bought shocks for a 4" lift. Should have bought 5100's myself instead of the cheap Pro Comps but I'll replace them eventually.
These are my shackles...they are 4.75" pin to pin.
http://man-a-fre.com/pa3/MAFShackleandSpringPinKits.htm
Flex it up and mesure is the best way to tell. If you have to guess I would go 4" but I would mesure to be sure.
I have the 2.5 OME springs, the anti-inversion shackles, and just put the 4" 5100 bilsteins on it. The recommendation from my local 4x4 shop that I ordered from said that bilsteins run a little short. They fit just fine. I was nervous about the front as the shocks only have about 3" of exposed piston but I don't think the springs will ever compress to come close to bottoming them out. I used my high lift to pick the corner of the truck up and it still wasn't close to compressing that much.
I ordered the Bilsteins for a 4" lift. One set ended up being much too long, so I sent one set back and got one set for a 2" lift. If I recall, the rear has the longer set installed.
So the answer (for me) was you need two 2" lift and two 4" lift shocks.
I like them. I have only put a few hundred miles on them so they are not even a little broken in. I have no complaints other than my lifetime warranty is gone.
Any chance you could get those Bilstein part #s? :)
33-185606 Front ?
33-185552 Rear ?
Is what I'm looking at, but it's a bit confusing without having the springs on and being able to measure....
:D
I'm sorry to hear of your passing.
It just sucks buying something thinking you have a lifetime warranty and a few months later, POOF it's gone.
I have the 2.5" OME, medium front and heavy rear. I went with the 2" lift rates Billsteins. I've had no complaints.
