Have some of you found a problem with the power steering pump, after set your tires.
Or this pump work fine even some 38.1
Thanks in advance!
Thanks in advance!
Yeah with a marginal pump or steering box big tires will definitely kill them. I had to upgrade to a psc rebuilt box after I installed 40's. You gotta figure the fluid will heat up and thin out more too which will allow it past the seals. Plus the increased resistance and force on the snout of your box trying to control those tires, if there was any slop there, big tires only makes it worse.
