Gonna redo the new 40. The instructions say "solvent", but what solvent? Any recs appreciated.
bsevans said:I went to an automotive paint supply store and got a weatherstrip adhesive remover made by 3M. It works, but required a lot of elbow grease. I think the level of work depends on the hardness/age of the adhesive.
Degnol said:Ditto, and also depends on whether they used yellow or black weatherstrip adhesive. Yellow much more difficult to remove. IIRC
Are you trying to preserve paint? I was not concerned about that and zipped it off with a tufted wire wheel and an angle grinder.
HTH
Ed
greytandy said:Anybody tried one of these?
http://products3.3m.com/catalog/us/...us_aad_3_0/command_AbcPageHandler/output_html
73lndcrsr said:I use them on gaskets, but they will damage the paint.
Pete said:X2 on the 3M weatherstrip adhesive remover. It helps to let it soak in and soften up the real old hard stuff and to scrape exess off. This is an excellent all-around cleaner, solvent. Also removes the gaudy decals the PO put on.....
Pete
Degnol said:So buy two cans instead of one. The stuff was really designed to remove "fresh" adhesive, but as Pete says, let it soak.
Pete said:Also removes the gaudy decals the PO put on.....
greytandy said:How 'bout a quart?
