Gentlemen, I have a Chevy 350 with a 350A/T in my 1965 FJ40. I still have the original 3 spd transfer case. It screams at me going down the road over 50mph. What have any of you put in as a sturdy off road but still good for highway solution?
Have you thought of just rebuilding the tcase?
There are many options and they all depend on your goals for the truck.
Weekend blue trail wheeler and street driver, or neighborhood queen/ice cream getter, or serious wheeler with street manners, or trailer queen hard core trail rig...
It will be mainly street, beach, snow and a few trips on the trails with you all. You know how much I work. It won't see a huge amount of hard core action.Have you thought of just rebuilding the tcase?
It would be years before I could afford to do all of that. A split case was mentioned before. If a rebuild could tame the howl I'd be okay but I want to be able to drive it at highway speeds and not sound like an explosion is eminent.Jake's idea is solid, the split case is much mo better. However, i'd go right to a NP205 or an Atlas then do a centered rear end.
If you do an Atlas the adapter is really short - only about an inch long so you will have the best driveshaft length and angles.
Call Advance Adapters and ask for Vic. He is a really solid guy - George Ester at Valley Hybrids would be an ideal source as well and is also a totally reliable and solid vendor.
If you do the 205 it's cheaper and bolts up to the trans you have with factory adapters but then you will spend money on the rear. You can do a centered mini truck and Cruiser hybrid axle with a cruiser center and mini shafts or you can run a mini truck rear with a stronger V6 third. I'd run a narrowed nine inch with a CV shaft.
The case may be streached. No mater how much rebuilding it may still wine.
What helped mine was taking the top off. The noise has a place to go then!!
Jakes40 - How is that 6.0 holding up? My buddy Johhny just bought one in an F450 and is giving it the once over. GLTHFJ60 here on mud
I concur, but it is about to go back on this week. Now I need to fix it or move to FL.I should have explained the fix better.
The top I took off was the roof. With no soft or hard top the wine is almost unnoticeable!!!
