I'm going to add a Racor separator(leaning towards a 230) to my HJ61 and was wondering where the easiest spot to place it would be. There doesn't seem to be a lot of room under the hood.Wondering where people had located theirs.
I don't have a 61, but I have thought about adding a racor to my rig.
I would put it in the back right part of the engine compartment.
Lots of room back there.
It's the perfect spot, as its right next to the injection pump, and stock fuel filter.
I would put the racor in line as soon as the fuel line enters the engine compartment and before the stock filter.
I beileve most racor filters also are water seperators with a green and red light, so it would be easy to move those into the cab. Possible mod the "fuel" light and put the green and red LED behind it. But if your going mod the light housing, you will want to remove the stock water filter, because your racor would be infront of it. So you would not want your stock one, as if it ever plugs/fills you will have no way of knowing since you removed its light.
Also, just to add, my girlfriends 3B powered FJ55 has it in the right back.
Not sure how it is exactly plummed in.
Cruiser_guy would know better because he installed it when be build the truck!
Cheers,
Nick
Anyways, here is the pic of the engine back.
Lots of room in the back right.
Also, I wonder if running two fuel filters inline is going to cause a problem with flow? Imagine making your coffee in the morning and doubling up the paper filters, chances are your water will back up and spill over the top.
I don't think having 2 fuel filters would make that big of difference.
If the pump system is designed to draw or push fuel through a 20 micron filter, and you install a 30 micron filter inline with the orginal, then I agree with you (though this would seem pointless). If you install a 5 micron filter, then how do you propose to offset the resulting loss in fuel flow? You've essentially added 6 times the resistance through the filter system without increasing the pump output. The feeder pump that supplies the injector pump is going to struggle to do its job.
