Hey fellow Mudders I have a brake question.
I am using 60 series axel's in my 1969 FJ40 build and most everything except the rotors and pads look pretty corroded. Drums have a big lip on the inner edge and are no longer thick enough to turn. Slave cylinders might still have enough meat to hone..... I guess. Caliper pistons appear to be stuck in place but haven't really trying messing with them yet. Should I try and rebuild this stuff?
Sounds like the 80 series non ABS master is the way to go and custom larger break lines are needed. I have a booster from a 60 but don't want to cut the rib on the fire wall so plan on going unboosted. Also going with the OME 2.5" lift and 33s so longer flexible line's.
Read a bunch of thread's and have an idea of what I should do but would appreciate any input you guys have.
Thanks!
Here is the link to the rest of the build for reference.
forum.ih8mud.com
Thanks!
The 60/40 Project
OK so I'm starting this thread about a 1969 FJ40 I bought from a family friend as my first vehicle about 30 years ago. It was originally a faded blue and had some really roughly plastered on Bondo on a rear corner panel and a hand welded lumber rack that the original owner used to haul heavy...
