I replaced my radiator a 3 months ago, and replaced my leaking Ps pump in the process as well as all of the lines. While fitting the tight 3/8 line on the the cooler, I slightly bent the cooler tube. I connected everything up anyway because the bend did not leak, but I think the constriction might be causing my problem. I can make a geyser just by turning the wheel with the engine off (wheels off the ground).
I've done the fsm bleed procedure over 5 times with the front axle on stands. I've also tried a few bleed procedures mentioned here on mud, but the volcano will not go away or even decrease. It almost appears to be a geyser instead of foam. I'll list what I replaced.
New oem Ps pump
Toyota Atf
High pressure line from cruiser parts
Oem reservoir line
Sienna line to cooler
Generic 3/8 line from cooler to reservoir
There are no leaks anywhere and my steering feels normal. Slight whine when the steering is at lock, but nothing extreme. This is my dd so I would've thought any air trapped would have bled out by now with normal driving.
My only guess is that the bend caused a constriction that is acting like a nozzle for the Ps fluid going back to the reservoir. I have very limited experience with hydraulic systems. So if someone could tell me if I'm on the right track that'd be awesome.
I've been working on this problem for a while now so it's hard to be objective. Maybe the infinite wisdom of mud can shine some light! Thanks!
New oem Ps pump
Toyota Atf
Oem reservoir line
