Bending 4x4labs Steering Arms? (1 Viewer)
Bripars40
Oklahoma
I posted this in the Hardcore Section but wanted to see if anyone would know in this section.
My 40 is setup with Luke’s hi-steer arms, but the angle is set for higher lift than I have now(SOA, shackle at the front, flat stock springs, 37s). I’m trying to lower the front as much as possible, and now that I’ve lowered it the tie rod contacts the frame if I hit a big bump while driving.
Can I heat and bend the steering arms to decrease the angle of the arms? Ideally, the bottom of the tie rod would be about 3/4”-1” above the springs. It’s about 3” now.
Can you get it hot enough to bend?, If it's like mine, it's a pretty thick chunk of steel.
Luke bent mine cold in his press. Call him.
