You know what I really appricate about MUD, the fact that when I ask a dumb question. I get help.
Not try searching.
Thanks.
You *do* realize don't you, that Dan didn't have that information on his fingertips. He probably entered a few key words into the search, spent a few minutes locating the best thread, and handed it to you on a silver platter.
Your question wasn't dumb. You also shouldn't expect someone to do your SEARCHing for you just because they are better at searching than you are.
-B-
yeah, you can use a 9V battery with some leads on it to power the actuator.
All my issues were in the front. It hadn't failed, was just dirty. If you have it on the bench I would just use 9V, the 12V will move it too fast to adjust the position and the FSM recommends 9V. 12V won't fry it (that is what it runs on normally).
The problem isn't a failure in most cases, just old hardened grease or unglued magnets in the motor. If you are in the rust belt they can also rot inside. Almost every one I have seen or heard of you can clean it up and it will be as good as new. Mine fire within 1-2 seconds and lock up very quickly.
