Belt Question (1 Viewer)
Big D
OK, so my PS pump goes out and i am still in need of a smog pump. So to get my rig up and running can i run a belt around my alternator, water pump and fan? If so does anyone know what size that is? Also, my AC is crapped out as well so there is no belt there either. Is it too much stress on the truck to just have one belt?
You are in luck. You have two options:
The A/C belt will fit around the alt/water/main pullys. (Wierd, but true.)
A 15A 1230 belt (a bit thicker than the A/C belt) will also fit.
You are fine with one belt. Prolly could run forever this way.
I posted some pics of an alternate setup, do a search for belts and smog.
YOu could also use some garden string or jute or something to measure what length you need then explain to the parts guy at your local store what you need. He'll probably let you just go try to match up the string to the belt .
BS, did you get the PM that I found a couple of smog pumps?
