Bellhousing gaskets?
Thoughts on using gaskets or liquid gasket when reinstalling the flywheel cover plate? On the SOR website it appears that there are suppose to be gaskets, though they are no longer available from them.
Thanks!
Dave
Bellhousing gaskets
I'm not familiar with 60's, but on the two different bellhousings I've used on 2F engines in my 40, there were never any gaskets on the inspection covers, nor can I conjure up any reason for a gasket at that location. I know my current inspection cover has a hole punched into the exact center/low spot in it, so if anything needs to drain out it can, so I really can't see the need for a gasket.
I guess if you want some extra practice applying RTV, it wouldn't hurt anything
Don't add a gasket sealer..
No reason for it other than to reduce rattles..
Thanks for the replies...spent a few hours this afternoon hoisting the engine and pulling the bellhousing of this stock 79 FJ40. There are indeed gaskets (5 strips) on the flywheel inspection cover. I suspect merely to reduce rattles...
Cheers,
Dave
