Holy crap you have your work cut out for you. That's a lot of rot.
Every time you come down to the basement, you will be glad you installed the wood (Doug Fir?) beams instead of the LVL or glulam. They look bad ass and much more pleasing to the eye. Awsome work.![]()
What are the loads on those posts and beams? Overkill? Not complaining, but I like the sound of overkill. Maybe you have to take earthquakes etc into account when doing a load spec in that part of the world?
Back at it - chasing down rot wherever I can find it, which in this house appears to be everywhere. Had some time Friday but not a real good plan so I figured I'd start removing siding since I knew it would have to be done eventually to get a new window installed in the kitchen.
I got the top layer of tiles off and decided to pull the fake brick off the bottom to see what was there. I knew it wasn't going to be pretty and was pretty sure I'd be building a new pony wall between the foundation and the house. I was right. I ended up working about 10 hours Friday and another 10 hours Sunday.
I'm pretty sure the house was originally post and beam and the foundation was added at some point. There were posts about every three feet on the foundation and they were rotten. I suspect there was dirt up against the side of the house for some time that caused the problem. It has been pretty apparent that the PO's fixes consisted of just covering up the problems.
Anyway - I've been here before. Got about half of this side done and I think the second half will go a lot faster. I can see a couple of 4x6's that I put in when I removed the store front 10 years ago. I hope I did a good job back then and won't have to mess with that part.
I've also decided this asbestos tile is not going back on. At this point, I'm better off just installing Hardiplank. I think I can get most, if not all of the house done this year.
Now for the pictures.
1. Tile removed showing fake brick
2. Rotted cedar under the brick
3. Cedar removed
Wow the fake brick tile brings back so many memories of my grandfathers home. His house was built in 1920, that must have been all the rage back then.
Excellent work btw. Where did you acquire your skills?
Zack
If that is asbestos siding hang on to it until you reside the whole house, then take it down to a recycle center for cash. A lot of folks still use that and are willing to pay good $ since it is no longer made & practically indestructible once installed. Brittle as crazy but great stuff.
