Hey fellas, i'm kinda new to the 100 series crowd, i own a 79 fj40 and a 73 fj55 pig. My buddy has a 1999 100 series that has been put through hell. Its got 180k on it, runs perfectly. In the last 10k miles he has put new windsheild on it, water pump, timing belt, starter, ALL new rotors front and rear, new calipers front and rear with pads, tuneup, and a nice pioneer cd player. All work done at toyota dealership with toyota parts. Everything on the truck works from what i've seen. But i will tell you this truck is DIRTY, leather is good but cracked a little, carpet needs a GOOD shampoo for sure. Body is 100 % straight, but paint has lots of clear coat scratches. It has a 2.5 inch lift on it, front brush guard, 33 inch bfg mts with about half tread left.
Now here are the negatives.
-Powersteering pump is dead, but a new pump from toyota is provided, easy install, no biggie
-1st gear on the transmission slip pretty bad when you stomp on the pedal, it actually hits the rev limiter before it shifts.. But it shifts ok if you drive normal. Its been like this for many miles and hasn't got much worse. All other gear shift fine.
-And the worst of all, the front diff is blown, its either the ring and pinion or the spider gears, not sure. I would be doing all of the labor myself, i just would like to knowhow much it would cost to replace the ring, pinion and bearings?
Price for truck is $5000, what do you 100 series mud fellas think i should do? I would really like to know how much the front end parts are gonna cost me. And is the toyota v8 a good motor? I can tell you the PO (my friend) isnt really good about oil changes, he tends to go over all the time. Thanks!!
