- Year
- 2000
- Vehicle Model
- 100 Series
- Location
- United States
- Mileage
- 215000
- Color
- Silver
Hi there,
Looking to pass this unicorn on to the next lover of LC's
Time for me to move on due major changes, all for the better.
Been over serviced since purchased. Purchased from an Air Force jet mechanic in Texas. Totally rust free at purchase. Owned 5 years in NY/NYC. Garaged, not a DD.
Price depends on the "extras" (tent, fox wing, fridges etc.) wanted/needed.
Originally built to do the Pan-American hence the extensive service.
(Picture OBX around 2018)
Opps, ran into a limit of pictures. Fun times!
Services
(Dont want to post all of it online with all my personal info will provide all to buyer.)
Just an example of the love:
2020
October
Passenger front wheel bearing
September
Oil change 210000
Front diff and transfer case oil change
Output shaft bearing change
New ac lines & condenser
New HT tires
Parts
90311-47013 Axle Seal
90363-43001 Outer Bearing
Change Ac condenser
Mobil 1 diff fluid front and rear
Synthetic grease
Install heavy duty rear springs w air bags
2020 June
All new real links OEM upper metal tech lower
Front diff brackets
Driver lower control arm
January
Front
Nitro uca
OEM lca
Rear
Metal tech lca
OEM ucl
Front wheel bearings
Steering rack & tie rods
Arb shocks
Trd rock warrior rims
Toyo AT tires
November 2019
Balance tires and alignment
New OEM rear upper trailing arms
November 18, 2019
203,615 miles
Oil change and filter
Diff oil change front and rear
New air control valve 17630-16040
September 2019
New OEM starter
June 10, 2019
199466 miles
Oil change.
September 7, 2018
Oil Change
Right side all new start plugs, coils and coil gaskets valve cover gasket.
Left side changed out coil 2 & 3 from the right side.
Fixed all the error codes
August 22, 2018
Fix Issues
P0300 Random Misfire
p1305 Igniter Circuit Malfunction #2
p1310 Igniter Circuit Malfunction #3
p1320 Igniter Circuit Malfunction #5
p1340 Camshaft Position Sensor or #8
July 5, 2018
A/C Leak fixed
Left side lower ball bearing replaced with Moog
June 23, 2018
Tire rotation front to rear.
Install Driver side lower ball bearing
Aug 2017
Fix
Pulls to passenger while accelerating
Wobbles when breaking
Pull diminishes while cornering passenger if the turn is banked
Downshift acceleration pulls significantly to drivers
None highway driving no pull only steering wheel shake
December 2016
Driver side front lower
Steering rack
Outer tie rod's
Dust covers
Gaskets
Front inner and outer wheel bearings and seals
November 2016
One 1.5 to 2° positive caster added to the alignment
Currently driver side is off by 1 inch with driver in vehicle
October 26, 2016
1. 1. Inspection
2. 2. Swap chipped tire with new tire (BF Goodrich AT KO2)
3. 3. Dispose of spare tire (BF Goodrich AT KO) replace with the chipped tire (BF Goodrich AT KO2).
4. 4. Install Warn winch and winch line.
September 12, 2016
Start issue
New Aux battery
Muffler
August 4th 2016
Front bumper
Side steps
Winch
Winch rope
Abs sensor dr rear
Brake line dr rear
Starting issue
Rear trailing arms
New Gas tank
Fix Skid plates
Rear dent dr rear
Scratches in the paint on the sides
Front lower control arms
Tires
Maintenance
Replace Front brake rotors
Remove winch to be sent back for warranty
June 27 2016
Skids
7 way harness
Lift front bumper
4/5/2016
Intermediate Steering shaft - check
Grease the bushing around the Steering rack?
Skid plates - price
Add a 40 gal tank - price
lower Ball Joint - check
Turn rotors or replace?
Toyota Front Axles
Toyota Steering Rack
Toyota Tie Rods, Outer and Inner?
2016
February-March
Alignment
Balance
Arb Air compressor
Dual battery system
Fix the sliders
December 31, 2015
1 800 331 4331, 3
Toyota Motor Corporation
Case Number: Land Cruiser
1512310604
212 315 3939
70121
Case Number: Highlander
1602022319
1602222386
December 14 2015
Fix Pulls to the right
Steering wheel swings left and right
Install ARB air compressor
Fix
Tow package (no right indicator)
Rear wheel bearings?
Rear diff? Pinion bearing?
November 30, 2015
Check front passenger boot sleeve
Identify the sloppy sounds and banging in the rear; check all bushings, sleeves, joints and links.
Install new OEM Alternator (in the trunk, Toyota box)
All parts must be OEM or better. I get parts discounted from different sponsors, please let me know if I need to order anything parts related.
November 25, 2015
Order
Bushing sleeve x2
Wax oil
November 2 2015
NYS Inspection
Tighten Emergency break
Check Rear breaks
Check Alternator
Check Rear sway bar
Install new T connector if needed
(Trailer passenger break and blin
ARB air compressor
Check transmission oil
June 2015
Fix A/C
Fix the leak/whistle coming from the new manifold
Install Torsion bars
Front end alignment
Balance tires again
Install ARB Air Compressor
If time install Spod wiring kit
If time Install rear tail light
May 26 2015
Spod
ARB Air compressor
Fix knock in the rear
Balance tires again
Torsion bars
Light bar bracket
Fix trailer wiring
Fix exhaust rattle
May 19, 2015
Install
Doug Thorey Cat back Exhaust
Touch up paint
A/C
April 23, 2015
Install:
Scan gauge
Torsion Bar
Re align
Heat shields
OEM
April
Curt at just differential
Spod Universal kit $370
Hookup for the Puma compressor
Jerry Cans x2 $160
OME torsion bar for the front ?
Roof top Tent $1500
March 2015
Install parts delivered by UPS on Friday.
Check roof rack for possible leaks
Center steering wheel
Check balance
Make sure snorkel is 100% water proof/ seal with silicone.
Make sure the firewall 100% water proof.
2017 Q1
Cab mount front driver
Strobe lights
Abrams Siren/PA system
Antifreeze flush New Synthetic fluid
Power steering flush Synthetic fluid
Greased all zerks
New Remanufactured Steering rack and pinion
New Passenger Side CV axel NAPA Warranty
New Front ABS Dust Shields front
All new OEM gaskets
New Outer Tie rods
New Bearings front
New Brake insulator kit
Readjusted HD Torsion bars (level ride –front and rear)
Re alignment positive 1.5-2 degrees
2016 Q2-3
Mobil 1 Synthetic Gear oil service
Mobil 1 Synthetic oil service
Greased all zerks
Toyota Dealer Serviced
New OEM Rear End (Carrier) with 1 year warranty
All new OEM exhaust heat shields
New OEM alternator
New OEM Front Rotors
New OEM O2 sensors
New OEM ABS Sensors
New 5x BFGoodrich KO2 AT 285/70R16
New OEM Drive Side CV boot
New HD Rear Trailing arms and brackets
New OEM Fuel Tank
New OEM Fuel Tank Straps
New Trailer wiring kit
New OEM Lower control arm
New Sway bar links and bushings
New Toyota Muffler (last part in the rear end # 17405-50030, the Doug Thorley Headers cat back exhaust was too loud for me)
New Passenger Side CV axel NAPA (needed the cruiser back fast for a trip hence NAPA)
Alignment
2016 Q1
Greased all zerks
2015 Q2-3
Repack front bearings
New OEM headers
New OEM brake pads
New E-Brake shoes etc.
New Transmission fluid
Rear airbag installed (removed bump stops)
New Steering rack bushings
Mobil 1 Synthetic Gear oil service (why the hell not)
Greased all zerks
Alignment
2015 Q1
Greased all zerks
Alignment
2014 Q3
Toyota 150-point inspection prior to purchase. Test came back “would you be interesting in selling it” - Toyota master mechanic NJ.
Rust “proofed” the undercarriage 3M product done by local body shop
Greased all zerks
2014 Q2
Timing belt @ 140k
Relocate diff breathers
Greased all zerks
New 5x BFGoodrich KO AT 285/70R16
Tire Balance
Alignment
Extras:
2016 Q4
ARB Intensity 9.5 inch knockoffs (very happy with them, so good ARB - Rigid made them take them off the market.)
Warn Warranty Winch Repair
Warn Warranty New Synthetic Winch Line
2016 Q3
Dual Batteries Oddessy 31M
National Luna Battery Management
Designated power cables to trunk with x 2 cigarette outlets (for fridge etc.)
ARB air compressor
Tekonsha Prodigy P3 Trailer Brake Controller
Custom metal skid plates (Belly, Intermediate and Front)
ARB 63Q Fridge with Slide (Wife thinks the Cruiser has the space of an RV)
2016 Q1
Warn 9.5 xps
ARB Bull Bar Deluxe
ARB Sidebars
ARB Steps/Sliders
ARB Safari Snorkel
Rigid Industries 150312 E-Series 50" LED Spot/Flood Combo Light Bar (Front)
Rigid Industries 98002 SR-Q Diffused Back-Up Light Kit (Sides)
Rigid Industries 20251 Dually 60° Lens (Rear)
Spod Universal with Modular 6 Switch Panel
Rhino Rack Pioneer Roof Rack 84 x 56 inches
Rhino Rack Leg Kit
Rhino Rack Pioneer Platform Front Rail
Rhino Rack Foxwing
Rhino Rack Foxwing 4 x Tapered Zip Extentions
Rhino Rack Hi-Lift Mount
Rhino Rack Foxwing Mount
Pioneer Eye Bolt Kit x 2
Pioneer Combination Bracket
Hi-Lift ARB bumper Mount
ARB 50Q Fridge with Slide
2015 Q4
Bilstein Shocks Rear
OME HD Torsion bars
OME HD load 3-inch springs (extra set)
Nitro Upper Control arms
2014
CB Radio
Pioneer Dash with Bluetooth hands free and music
Bilstein Shocks
Slee Differential Drop
OME Med load 1.5-inch springs
Slee battery tray
Die Hard Plat. 31M
Annual Service & Install Costs
(Does not include purchase of aftermarket gear)
2015
Est. $15,000.00
2016
Est. $10,000.00
2017
Est. $3000.00
Services
American Express | Transaction Details | / January 1, 2014 to June 9, 2015 | |||
Prepared for | Search results for "toyota" | ||||
Date | Description | Amount | |||
08/27/2014 | TEAM TOYOTA OF PRINCLAWRENCEVILLE NJ | 123.05 | |||
11/22/2014 | TOYOTA OF MANHATTAN NEW YORK NY | 2,448.07 | |||
11/25/2014 | WHITE RIVER TOYOTA 802-299-2800 | 162.70 | |||
12/02/2014 | PAYPAL *TOYOTALANDC 4029357733 CA | 45.00 | |||
12/05/2014 | TOYOTA OF MANHATTAN NEW YORK NY | 12.00 | |||
12/05/2014 | TOYOTA OF MANHATTAN NEW YORK NY | 546.19 | |||
12/23/2014 | TOYOTA OF MANHATTAN NEW YORK NY | 722.60 | |||
01/09/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 481.70 | |||
02/20/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 1,437.87 | |||
02/26/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 71.45 | |||
03/06/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 180.00 | |||
03/20/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 360.00 | |||
05/08/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 2,268.84 | |||
05/22/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 586.90 | |||
05/25/2015 | PRESTIGE TOYOTA 845-339-3313 | 53.27 | |||
06/05/2015 | TOYOTA OF MANHATTAN NEW YORK NY | 630.00 |
2020
October
September
Oil change 210000
New HT tires
Parts
Change Ac condenser
Synthetic grease
2020 June
Front diff brackets
January
Front
Nitro uca
OEM lca
Rear
Metal tech lca
OEM ucl
Arb shocks
Toyo AT tires
November 2019
November 18, 2019
203,615 miles
September 2019
New OEM starter
June 10, 2019
199466 miles
Oil change.
September 7, 2018
Oil Change
August 22, 2018
Fix Issues
July 5, 2018
A/C Leak fixed
June 23, 2018
Aug 2017
Fix
December 2016
Steering rack
Outer tie rod's
Dust covers
Gaskets
November 2016
October 26, 2016
1. 1. Inspection
September 12, 2016
Start issue
New Aux battery
Muffler
August 4th 2016
Front bumper
Side steps
Winch
Winch rope
Abs sensor dr rear
Brake line dr rear
Starting issue
Rear trailing arms
New Gas tank
Fix Skid plates
Rear dent dr rear
Tires
Maintenance
June 27 2016
Skids
7 way harness
Lift front bumper
4/5/2016
Skid plates - price
Toyota Front Axles
2016
February-March
Alignment
Balance
Arb Air compressor
Dual battery system
Fix the sliders
December 31, 2015
1 800 331 4331, 3
1512310604
212 315 3939
70121
1602022319
1602222386
December 14 2015
Fix
November 30, 2015
November 25, 2015
Order
Bushing sleeve x2
Wax oil
November 2 2015
NYS Inspection
Check Rear breaks
Check Alternator
Check Rear sway bar
ARB air compressor
June 2015
Fix A/C
Front end alignment
Balance tires again
May 26 2015
Spod
ARB Air compressor
Balance tires again
Torsion bars
Light bar bracket
Fix trailer wiring
Fix exhaust rattle
May 19, 2015
Install
Touch up paint
A/C
April 23, 2015
Install:
Scan gauge
Torsion Bar
Re align
Heat shields
OEM
April
Jerry Cans x2 $160
Roof top Tent $1500
March 2015
Check balance
2017 Q1
Strobe lights
Greased all zerks
All new OEM gaskets
New Outer Tie rods
New Bearings front
2016 Q2-3
Greased all zerks
New OEM alternator
New OEM O2 sensors
New OEM ABS Sensors
New OEM Fuel Tank
Alignment
2016 Q1
Greased all zerks
2015 Q2-3
New OEM headers
New OEM brake pads
Greased all zerks
Alignment
2015 Q1
Greased all zerks
Alignment
2014 Q3
Greased all zerks
2014 Q2
Timing belt @ 140k
Greased all zerks
Tire Balance
Alignment
Extras:
2016 Q4
2016 Q3
ARB air compressor
2016 Q1
Warn 9.5 xps
ARB Bull Bar Deluxe
ARB Sidebars
ARB Steps/Sliders
ARB Safari Snorkel
Rhino Rack Leg Kit
Rhino Rack Foxwing
2015 Q4
OME HD Torsion bars
2014
CB Radio
Bilstein Shocks
Slee battery tray
Die Hard Plat. 31M
2015
Est. $15,000.00
2016
Est. $10,000.00
2017
Est. $3000.00
