battery terminal replacement
VA
RussBow6 said:
stupid question probaly... but what battery terminal cover will fit 34-003N - TERM BAT TOP NEG 3/8 MILITARY terminals? http://www.wranglernw.com/commerce/ItemDetail.asp?ItemNo=34-003N
and when replacing the old terminals how do you dis- and reattach the cable from the terminals?
thanks
~Russ
I'm a novice at this battery stuff but you will either need to get a new negative battery cable or cut and crump a new end on it. For the positive side you can drill out the larger cable to fit the larger bolt on the military terminl. You wil probable have to cut and crimp larger ends onto the smaller positive wire. Remember that these contacts need to be done very well and shielded from the elements.
You can get the military terminals a lot cheaper at a NAPA warehouse.
