Battery size for 5.3 swap in fj62 (1 Viewer)
Nashville
Hey mud!
I have asked a lot of questions lately, and this one pertains to the battery size I need for my new setup. The optima that is in the rig now is 5 years old and not holding charge (no surprise there).
What size battery do I need to get for my 1988 that has a 5.3 LS motor in it? I was thinking of getting a battery that would work for a 2003 Tahoe, since that is the year/model that the engine is ou out of. Advance auto parts said a group 78 would fit a Tahoe with that engine.
My first instinct is to get the biggest damn battery that will fit the tray, but that is just knee-jerk logic.
Anyone?
thanks, happy 4th of July!
Joel
So bigger is better then? The size I have now is 34/78
I use a FJ60 factory replacement Interstate battery (from Costco) with my 5.3 swap. Zero issues. Group Size 27, 810 CCA, Item # 1130806 has the terminals in the correct (at least for FJ60) orientation.
A medium sized AGM battery will make that engine jump to life when starting. A medium sized AGM will outperform a giant wet lead acid for starting duties - especially in cold weather.
There isn't a need to get a giant AGM battery- way overkill for starting.
A palm sized lithium ion jump start battery (normally used for emergencies) can start that engine fine.
Upgrade to the 27 series
you can even get the “marine” battery with 750-800 cold cranking amps for around 100$ at oriellys right now
even the high end batteries big name brands were only putting out 800 cca so cheap bang for your buck.
