Battery light on - what could cause it
Boston suburb
LC 07, 190k, alternator replaced at 145k, battery replaced in October, 2019. Battery light on dashboard turned on two weeks ago and today. Both times turned off after starting a car and running it for a bit. Car was seating on a driveway without driving since Sunday - not that long.
Do I have a leak in electrical system draining battery? Something else?
Calgary
Could be a drain somewhere. Disconnect a battery pole and test with ammeter. If you see 0.1 amps thats 1.2 watts per hour your battery is draining at. If you have a 600 Amp hour battery you should have 6000 hours before it's dead or roughly 6 months.
Boston suburb
Alternator was done by previous owner at Toyota dealership - hopefully it is Toyota remanufactured one. Will check for a drain. So far - light is not coming up after a bit of driving.
