Battery Isolator, or hook in series?
Discussion in 'AR- Razorback Land Cruisers' started by Paul78FJ40, Feb 10, 2018.
  1. Paul78FJ40
    Paul78FJ40
    84
    28
    Feb 23, 2017
    Batesville, Arkansas
    Ok, so I got a winch, and still need to install it. I think I need 2 batteries, and I want opinions on which is better, a battery isolator, or hooking 2 batteries in series?
    Also which is better, a double battery tray, or adding another single tray on the driver's side?
    Who sells a good double battery tray?
    Thanks in advance for your ideas, opinions, and thoughts.
  2. Travis 76
    Travis 76
    205
    Media:
    1
    60
    Jul 11, 2015
    Las Vegas
    Do not hook in series. That will double your voltage. Connecting them in parallel will not do that + to + and - to -. From what I understand an isolator keeps everything working better, more equal use and charge.
  3. Paul78FJ40
    Paul78FJ40
    84
    28
    Feb 23, 2017
    I always get in series, and in parallel mixed up.
  4. nimrod712
    nimrod712
    82
    37
    Oct 15, 2012
    Hot Springs, AR
    I wouldn't think you would need two batteries just because of a winch... In any event, a battery controller is the way to go, in my opinion. Can't really comment on the tray, other than I would consider weight, and, depending on where it's mounted you can get away with less wire.
  5. Paul78FJ40
    Paul78FJ40
    84
    28
    Feb 23, 2017
    Thanks nimrod. I don't know if I need to have two batteries or not, this is the first time I've had a winch. I may never need it, but there were so many times years ago, that I could have really used one. Instead, I used a hi-lift jack, shovel, a lot of sweat, and so much time.
  6. fjfodee
    fjfodee At a Medium Pace SILVER Star
    1,388
    511
    Dec 20, 2006
    Lower Left AR.
    No need for two batteries for just a winch IMO. Although, I might not have the conglomerate of crap on my battery if I had a second :hillbilly:. Still works fine tho.
  7. Paul78FJ40
    Paul78FJ40
    84
    28
    Feb 23, 2017
    Ok, thanks.
  8. nimrod712
    nimrod712
    82
    37
    Oct 15, 2012
    Hot Springs, AR
    Agreed. Not necessary unless you're planning to be winching multiple times in a short period of time. And even then, I've winched four or five times in a row with no issues. If you're still concerned, I'd go with a little bigger battery and call it good.
  9. Paul78FJ40
    Paul78FJ40
    84
    28
    Feb 23, 2017
    Ok, cool. I do need a bigger battery anyway.
