Here is the scenario. Battery is brand new. Alternator is putting out correct voltage. When the truck sits with key off, there is a full 12v draw. I can't find the source. I have it narrowed to the dome light fuse. All my door electrical door sensor pins are working correctly. The dome lights go on and off appropriately. The glove box light is working correctly, not grounded with box door closed.
Looking at the wiring schematic, it looks like the seat belt and carb cooling fan are tied to the dome light power, for what ever reason. My carb cooling fan seems to work correctly. Only switching on when hot, and shutting off when cooled back down.
So that leaves the seat belt switch or indicator. Is there a wire under the carpet tied directly to the belt where it clips in, and somehow hidden? This hasn't been a problem for 5 years, but changing the heater core seems to have made things weird. Should have changed the blinker fluid I guess.
And could the rear hatch light switch draw 12 volts, even if the light is off. Maybe the switch lever not in the exact spot to turn on the light, but still pulling power? Where is the rear hatch upper door closed sensor?? I figure if the door closed and the light goes out, the all that system is functioning properly.
Any ideas where to start testing? I have to pull the dome fuse to correct the issue. No fuse means no battery draw down.
It sucks to have a new $225 battery and the truck leave you stranded in 20 degrees at 2 AM!
Recently I changed the heater core, but I have already taken the radio out of the loop to know it isn't part of the problem. Same with all cig light plugs. Absolutely no items having power, and still a battery draw down, 12+volts
Ideas??
Ideas??
