So I am loosing .20v in 12hrs. on my battery.
Is that bad?
How low can my battery go before it wont crank anymore?
Thanks!
Is that bad?
Thanks!
Note: This feature currently requires accessing the site using the built-in Safari browser.
If you have a SBC in your cruiser. You are probably using an internally regulated altenator. If so is it a one wire or two wire hook up? If it is a two wire you need to add a diode or light bulb to one of the wires. I think it is the red one but not sure. This will help with the drain.
battling this as well... dead in a week.. never did this before.. (new battery) I think it might be my alarm system (even when not armed).
I had this problem on my Piggy. Tried chasing it with a meter and played pull the fuse games, no luck. Finally found a small ground inside the Chevy alternator. It was still cranking out full power when running, but it would slowly drain of the battery in less than a week. Swapped alternator for a fresh rebuilt one and no more problems. JohnI do not have a SBC but could this still be a possibility with the F motor? I have the diode just not sure exactly which wire or direction it should be hooked up...
