Basic stereo subwoofer question
Discussion in 'Chit-Chat' started by Cruiserhead05, Jul 9, 2005.
  1. Cruiserhead05
    Cruiserhead05 SILVER Star
    3,580
    150
    Jun 25, 2003
    Marshall, VA
    So in my 80 im running an alpine head unit which power the stock speakers and i have a small 10 inch pioneer power by its own amp in the rear. Sometimes when i turn my volume up to a certain point the subwoofer all together will just quit.
    Is this a wiring issue or a weak amp/cheap sub problem.
    Thanks,Brandon
  2. Stone
    Stone Moderator
    3,130
    8
    May 13, 2004
    BC, Canada
    A guess, but is your sub amplifier clipping? Maybe the gain is turned up too high, and after you get it past a certain volume the clipping protection in the amp kicks in?
    Just make sure that the amp driving your sub has adequate wattage for the sound pressure that you want from it. Distortion is what kills speakers. Good luck.
  3. Cruiserhead05
    3,580
    150
    Jun 25, 2003
    Marshall, VA
    Stone. my sub setup is just something cheap i picked up off ebay. its a boxed 10 in with a 200 watt amp mounted right on the back. i hope to upgrade to better components at some point but for now this fits my application. also i believe the sub is rated at 100 watts. i will check the gain setting and see when i find.
    Thanks
  4. chuglife
    chuglife
    506
    1
    Aug 15, 2003
    Calgary
    also, it's not a great idea to mount the amp right on the sub box, vibration can kill amps.
  5. RUfj40crazy
    RUfj40crazy
    209
    Sep 23, 2004
    Ride in VA now in NOVA
    Depending on the ohm levels for both you amp and the speaker it works both ways. If you speaker is of higher resistance then the amp is just not able to push on the coil and produce sound. The other is that the speaker is lower resistance and it’s possible that you’re overpowering the system; this will destroy the speaker coil causing it to unravel and cease to the magnet.
    My thoughts are that your just underpowered and when turning up your volume the amp has its max wattage and shuts down to avoid burning up the resistors.
    You also may need to check what the peak wattage from your deck is; low watt from the head units even when powering an auxiliary speaker can cause it to fizzle out.
  6. 89s rule
    89s rule
    5,073
    19
    Mar 18, 2004
    Abbeville, SC
    usually its when you are overloading the amp. my old system did that at times and i kinda took it to mean i needed to turn it down. I think you can tweak it a little with your settings on the HU and the amp.
  7. RUfj40crazy
    RUfj40crazy
    209
    Sep 23, 2004
    Also check your amp to see if it has a fuse...most have a 10a. If yours is a cheaper model and dosent have a fuse be wary of turning the juice up youll blow the resistors and scrap the amp!
  8. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,805
    Media:
    79
    Albums:
    4
    2,638
    Mar 6, 2005
    Mauldin, SC
    What he said.
    And it's clipping.
