Howdy! Basically it is the same engine. Some of the earlier years of 265/283/327 did not have all of the acessory holes drilled into the heads. Some of those had brackets that hung only on the water pump bolts, more less. Newer heads can be swapped in, or the holes can be drilled into the older heads, but that is not a good idea because the older heads do not have the thicker bosses in that part of the head and you will be going into the water jacket. You could even swap in a 350 as they are very common and inexpensive. The 283 is a marginal gain over the F/2F engine, while the 350 has much more power for the same size on the outside. John
