Welcome to the family!
I've had mine for about seven years but the summer of 2022 was when I finally
BEGAN BASELINING my 1997.
Ok, so...the extensive list...I haven't found one. BUT, I search MUD like an overzealous religious nut looking for meaning in scripture. MUD is your bible...it really is. Anything you can think of, do a search. You'll find tons of info. And even things you didn't know you were looking for. But an exhaustive list of intervals...? Not that I'm personally aware of. If there is, it'll probably be in the FSM
For me, tires were first as the previous were dangerously bad. Then the entire cooling system was redone...along the way, the electrical system was corrected, ignition system, new oil/filter (send a sample to blackstone after your first oil change so you know if you have a HG issue that might be pending)...Change out everything that's rubber and grease everything and change everything to OEM, if you can. It'll save you a lot of heartache.
Understand these are OVERBUILT; there's a reason why a PHH will last, in some cases, 200k miles or more (Mine was changed at 199K miles along with the fuel filter and ujoints). If it's bulging, change it ASAP. There are plenty of links in the forum on changing the PHH.
In my opinion, begin with the cooling system...in my opinion (again), that's the most important area to baseline...I began with the heater control valve because it's just as important as the PHH...if yours is yellowing, you need to change it.
New everything if you can...all hoses, heater control valve, PHH, radiator, water pump, thermostat, and fan clutch. Perform a full block flush if you can; RockAuto had the AISIN parts at a helluva good price. Go OEM on spark plug wires (My opinion).
Partsouq and ToyotaPartsDeal are your friend...at least they are for me. Many complain about the latter. I've never had a problem.
Get to know Wits' End and
@cruiseroutfit for parts...there are so many people on this forum that will help, but you have to do some legwork first and search.
Once everything is baselined...then begin to build.
Build to what YOU want and what YOU want to do.
Take a look at this article:
SHOULD I BUY AN 80 - COST OF OWNERSHIP - It'll help.
