I am working on my 2003 LX470 to get her refreshed and ready for some minor mods and a lot more use.
It has 238k on it.
Work already completed:
There's a rattle that, upon inspection looks to be the fan clutch or the pulley is already bad. Which would suck because it's the AISIN part frequently recommended. It was done at the same time as the timing belt and water pump.
What I am trying to do now is order the parts to refresh the suspension components, known bad issues, etc.
Would you more experienced 100 series owners please chime in? I added as much detail as possible to prevent the, "you may want to change your oil" commentary.
Thank you!
It has 238k on it.
- Timing belt
- Water Pump
- Fan pulley bracket
- 33" tires
- AHC fluid flush and refill
- Coolant flush and fill, new hoses
- DT headers (exhaust tick was ANNOYING)
- Steering rack, new outer tie rod ends
- Front and rear brakes
- Rotors
- Pads
- Parking Brake shoes
- ATF drain and fill
- Diff fluids
- Oil change
- Transfer case
Thank you!
