- Thread starter
- #21
Thank you!
Here's a pic of the starter. I only see two wires - one from the battery and the smaller one that I assume goes to the start position on the ignition switch.
On the coil, I removed the previous pic because I had it labeled wrong. The black wire from the disty goes to the negative coil terminal and the red wire from the disty to the ballast resistor. And then there are two more red wires from the green connector (they are bladed in) that come from I don't know where and attach to the ballast resistor.
Assume one of those 3 red wires is supposed to attach directly to the + terminal on the battery for starting?
