Bad Week for Fleet’s Roof Racks (1 Viewer)
Bryanseye
Inaffective Grammer Nazi
Between pit of man's fears and summit of knowledge
Website
www.upstatecruisers.com
Attended the Great Smokey Mountain Trail Ride last week and had a blast. Unfortunately I also got sucked into an off camber mud hole and snagged a tree with the hi-lift. Ended up ripping it apart and with the lift and had to rely on another to pull it to the side to proceed out of the hole. No knock on the Bowfin ( @dogfishlake ) rack, the 4” tree completely stopped the vehicle so there was substantial force. It bent both sides and shifted it back 2 inches. Hopefully some wrench and hammer time will bring it back, and a skid guard for the lift is planned.
Meanwhile, I left the other at home and someone borrowed it. It did not fit in the garage. 🤨🤣 The old KC 69’s appear to be the only casualty. I guess I was due for an upgrade since I put them on 18 years ago.
its like armor for your roof!
View attachment 2714629View attachment 2714630
You should be able to massage it back into shape. The aluminum will give that much, I don’t use 6061 because it is too rigid. The 5053 gives a nice balance between stiffnes and give. Use wood blocks for dolly’s and your powder coat should hold up fine
good luck!
good luck!
Thanks! Wood blocks and a plastic hammer are up first. I plan to remove the affected cross bars so I am only working one side at a time too.
