Bad transmission/clutch or something noise (1 Viewer)
BIG RENO AL
RENO NV
Hello again fellow mudders,
I recently installed a 4 speed transmission in place of the 3 speed on my 1972 FJ40. The transmission is an H42 from a 1976 FJ40.
I took the cover off and inspected for anything obvious to me but I just put in new seals and went with it. The transfer case I did rebuild.
Took it out for its first drive after getting the new engine running ( this engine is a beast!) and the transmission is squealing, whining, chattering on coasts and basically sounds like a dang Banshee.
What are the most likely sources? Bearings? Gears just plain shot? Worth trying to rebuild it? This is not a normal transmission whine. It is 10X louder.
Sorry for the poor video shoot but the sound is what's important.
Thanks
-AL
BIG RENO AL
RENO NV
I sure think so. I followed the instructions and a few threads here. But I may have done it wrong. It was my first time rebuilding a transfer case. The noise sure seems to be coming from the front of the transmission or the clutch area though.
KY
You're listening to the noise without a floorboard in place. Straight cut gears make more noise than helical cut gears. If everything is working properly then maybe some sound deadening material on the transmission hump will calm down the noise and make it liveable.
BIG RENO AL
RENO NV
Well you are correct that it is an open transmission/tcase and would naturally be louder that wth the hump in place. But the 3 speed that came out of it was so much quieter and if you can hear it there is a chattering or rattling when it is coasting. Especially in 2nd 3rd and 4th the whine is unnatural. I am almost sure it is forward of the tcace and seems to be at the front of the tranny maybe clutch area. If I look into the clutch inspection area can it be determined if everything is installed correctly?
BIG RENO AL
RENO NV
Well I pulled the transmission and the transfer case as one unit this morning. Going to crack them open and see if any thing looks mis-aligned or obvious. Especially going to look at the bearing that faces the engine on the transmission. Also thought the clutch might be in wrong but I looked closely at it and it seems OK. Need to scour threads about transmission evaluation. Any advice is greatly appreciated.
-Al
BIG RENO AL
RENO NV
Now thats an interesting idea. I think I have an 1/2 inch drill I'll try it. I assume I'm listening for unusual noise?
-AL
BIG RENO AL
RENO NV
Nothing obvious to my untrained eye. Everything seems correct. It on its way to Valley Hybrids tomorrow.
