Things were humming along just too well….
I am in the final stages of a frame off for my 1982FJ 45 Troopy from Saudi Arabia, a non-US F2 vehicle - it had a non functioning oil cooler, I replaced with a non cooler filter bracket
I have the new wiring harness in and was getting ready to test fire my engine that I refreshed two years ago. With no coolant and a few drops of gas, she popped nice and I got good oil pressure. Then I added coolant, popped it again and it ran for a few seconds and I noticed no oil pressure. In total it did not run for more than 10 seconds. I opened the oil drain plug and out gush water and mocha. The coolant from the block and the radiator were clean and fresh no sign of oil.
I pulled the rocker arm cover And no issues with the freeze plugs, and the oil looks clean and uncontaminated.
The motor ran fine before I removed it and all I did was have a head ground and freshened up.
Given the volume of coolant in the oil pan in a matter of seconds and no sign of leaking before the rebuild I am thinking I’ve got a plug missing or the head gasket may not be blocking a coolant circuit or an oil channel?
Could it be that the incorrect gasket maybe for a US engine used on this non-US motor could cause the oil and Coolant stream to mingle? Or is there a plug behind the water pump I’m missing?
Any tips on where to start short of pulling the head off would be greatly appreciated please let me know if you have any questions thanks
