Have removed the transmission cover and see what appears to be wire connections at the base of the gear shifter. Is this where the backup light should be connected? The previous owner had a switch on the dash for the backup light.
Thank you for that needed info. Much appreciated.@tlovvorn
Yes. There were two wires, and possibly depending on year, I believe red w/"lavender" (purple or blueish) that went to that switch. They were included in the wiring harness running along the passenger side frame rail.
One of the wires carried power from up front the other went to the light fixture in the back. The light depends on a ground through the frame.
My '72 only has one back up light on the left rear of the vehicle.According to the wiring diagram that I have for a '72 40 series the Back Up Light Switch is supplied from the Fuse Block by a LR wire. The Same color then goes to both of the Back Up Lights at the rear of the vehicle. It has been my experience that the wires are soldered at the switch. Easy to troubleshoot.
Then it would only go to one back up light, the wiring diagram I have shows two. There are differences within the same model year and errors in the drawings as well. Not to mention the wonderfulness of Previous Owners!!!My '72 only has one back up light on the left rear of the vehicle.
Why do you make the statement that it doesn't matter what color wire to use? They could use the WB wire that goes everywhere and make a real PO show out of the wiring, that will solve absolutely nothing. Use the correct color wire for the circuit so that you can troubleshoot the wiring later on when there are other problems. It would be a different story if the wire wasn't readily available but it is, from several sources.Test the switch pins to see if the switch is working first. Do a continuity test between the pins. Should be no continuity until shift lever is in reverse. If good, then wire it. Makes no difference which pin is the hot wire and which goes to the bulb. Makes no difference what color wire you use.
I know you didn't really ask anything except "Is this where the backup light should be connected? ". ........I offer the above just in case.
Thank you. That is certainly important to make sure it is working first.Test the switch pins to see if the switch is working first. Do a continuity test between the pins. Should be no continuity until shift lever is in reverse. If good, then wire it. Makes no difference which pin is the hot wire and which goes to the bulb. Makes no difference what color wire you use.
I appreciate the feedback. Thanks!Well, since you asked:
It's two wires. Following them can be done by a 10 year old. Even if doing a Barrett Jackson, you can't see those wires readily. Sometimes when someone is just adding something or rewiring something and they have some wire, they can just use it. If it disturbs you, don't do it. I try not to get upset by those kinds of things. Older vehicle wiring is simple and accessible for observation.
If comments and opinions to a poster are not allowed, let me know.
I tested it off and still not working. So where can I order a new one?Be sure to test it after it's out to be sure it's not the trans actuator that is the issue. Plunger out, no continuity............ Plunger in continuity.
Nothing on your FJ40 is universal, everything is way high and "special"
Thank you!@tlovvorn
IF your transmission is OEM THREE SPEED WITH FLOOR SHIFTER, the switch part no. is as follows:
Switch Assembly Back Up - Toyota (84210-57012) and lists for around $75.
You will also need a crush gasket, part no. 12157-10010 which lists for about $1.64.
These are both available from your local dealer.
Or, if you can wait a month and you trust Indonesian fit and supply quality, $33 and free shipping:
TOYOTA LAND CRUISER BJ40 FJ40 FJ45 FJ55 HJ45 REVERSE LIGHT LAMP SWITCH | eBay
Find many great new & used options and get the best deals for TOYOTA LAND CRUISER BJ40 FJ40 FJ45 FJ55 HJ45 REVERSE LIGHT LAMP SWITCH at the best online prices at eBay! Free shipping for many products!www.ebay.com
You will still need the gasket from the dealer..
Just got it ordered! Thank you!@tlovvorn
