For Sale B Diesel engine and transmission parts (2 Viewers)
Prosper, TX
I recently finished a BJ40 project and am selling all my extra parts. Im not completely up to speed on the values for this stuff but would sell everything for $5k if someone came and picked it up. Value of everything selling it piece by piece Im guessing would be over $10k, but honestly Im not an expert. I can send pictures upon request. Would rather sell all at once but if that doesn't work I will piece out. Everything is used unless noted.
notedqty
H41 Transmission and Transfer case
H41 Transmission and Transfer case with brake drum
Fan Clutch
Cylinder Head, Australian large valve, complete with valves/springs, still in plastic.new
Air Cleaner Assembly, paper element
Vacuum Canister
Flywheel
radiator screen, FJ because no extra tabs for Diesel logo, not sure of year but its original and in great shape.
camshaft, 3 bearing
Engine block 11411-56020
thermostat housing and neck2
valve covers, 1B-64 decal on one, the other is polished2
injectors, checked for operation at diesel shop.8
cylinder heads, dissembled, all parts. oem 11111-560202
cylinder head bare, oem 11111-56020
alternator with vacuum pump, no tags
engine fan with clutch, Asco, 7 blades, Blue base
engine fan, 8 blades, not fan clutch style.new
Fan with clutch, ASCO cast in clutch and fan, 7 blades, black base color
edic rod2
injector return line
exhaust manifold2
edic motor 12v, 28571-56120
timing gear set, used, appear to be in good condition
diesel injection line8
injector return line2
push rods, appear to have little wear, 256MM in length16
oil pan
air cleaner, paper element2
oil filter housing, downward facing
power stearing pump and bracket, 44443-60060 B2DA. Pump 60020
front timing gear cover and oil pump
intake manifold2
intake butterfly valve2
starter 24v, ND 028000-5550. Toyota part 28180-560702
gasket set -oil pan and timing cover missing. Teikin Oem #04111-59012new
edic motor 24v, 28571-56050
injector pump, ND 190000-1032
pistons and rods set, used, ART on skirt, 56013 inside, Toyota logo cast
rocker shaft2
Misc nuts/bolts/brackets/head bolts
Cam bearings, new 5, Clevite 77 SH-1481S
Short Block (Assembled)
24 v alternator, ND 100210-1401 Toyota 27030-56032
24 v starter, no markings, assume its 24V
24 v edic
block 11411-56020
pistons and rods, still in block, not inspected.
crank, still in short block, have not inspected.
pressure plate
camshaft and gears
fly wheel
oil filter housing is downward facing, filter screws in from the bottom
fuel filter housing, has used filter 23303-56031
injection pump, ND 190000-1032, 1050772, toyota 22100-56161
pullys
oil pan
OK, thanks, I'm starting to lean that direction. I will give it a few more day but have already received several inquiries like yours.
notedqty
Fan Clutch
Vacuum Canister
Flywheel
camshaft, 3 bearing
edic rod2
exhaust manifold2
oil pan
intake manifold2
rocker shaft2
24 v edic
block 11411-56020
pressure plate
camshaft and gears
fly wheel
pullys
oil pan
notedqty
Fan Clutch
Vacuum Canister
Flywheel
camshaft, 3 bearing
edic rod2
exhaust manifold2
oil pan
intake manifold2
rocker shaft2
24 v edic
block 11411-56020
pressure plate
camshaft and gears
fly wheel
pullys
oil pan
How much for the injector pump can you send me a picture
