For Sale B.C. Can. Toyota or samuri ultimate build parts
All parts NOT USED, assembled once or twice but NEVER USED, all prices are list prices I paid not including tax, freight or duty, which was a total of about 20% added to the cost of this stuff,.Was to be used for a suzuki build with all 1987 toyota running gear. STOPPED PROJECT BECAUSE WAS COSTING TOO MUCH AND COULDN'T FIND A GUY SELLING THINGS FOR LESS THEN 1/2 PRICE LIKE YOU JUST DID!!!!
Rocky Road Off-road 8" coil Suspension Lift for suzuki samuri, ultimate off road suspension for this SUV, welding to toyota 7.5" axle housings with all rebuilt front knuckles new parts and gaskets, paid over $2100 sell for $1050
Rocky Road Off-Road OTT high steer kit, paid $239 plus tax freight duty sell for $140
All-Pro Off-Road Rear Disc Brake kit for 86-04 toyota paid over $460
All-Pro Off-Road Chromoly Rear Axles for disc brake conversion, very strong for larger tires, paid $289
Sell both together only $375 would go good with the below All-Pro x-member set up
may need the 7.5" Toyota rear axles - All-Pro Off-Road Chromoly axles paid $289 will sell for $150 these are for rear disc brake conversions
All-Pro Off-Road toyota Triple X member which includes the crossmember skid plate, crossmember, parking brake rotor, caliper, lever,bushing sleeve,p.brake hardware, etc.
this is basically a crossmember that attaches to your transfercase and frame that has its own ebrake to the transfer case, no need to a regular parking brake, this also houses dual transfercases, paid $389
All-Pro Off-Road Dual transfercase adapter 21 spline, has two 1987 transfercases attached already, paid $289 for adapter alone.
Sell the Triple X member with ebrake and the dual transfer case set up for $700
7.5" Toyota front axles - Longfield Super Axles 2-4340 chromoly inners & 2-4340 chromoly birfields freeze hardened paid $600 will sell $300
two 7.5" 5:29 yukon gears, Longfield Super Axles freeze hardened with Detroit Lockrightlockers, new bearings and kits professionally installed includes housings
paid over $1800 sell $900
1987 toyota 5 speed trany with Marlin Crawler ceramic 1600 pound clutch, clutch cost $275 alone, sell all for $250
new set of "5" - 37" Super Swampers BOGGERS x 13 x15 ($2000) on new TRAILREADY aluminum bead locks, 15x10, 3.75" back spacing, 6 bolt pattern(5.5)($1500 direct from T.R.) with set of 4 Rapid Air Down valves($78), and regular valves as well, lug nuts (for toyota)($52) and lock nuts($48). Will fit Chev as well.
Total of over $3700 will sell for $3000 together
Box of 22RE throttle bodies and intake parts includes at least two bodies, housings, wiring looms, etc, sell for $100
new 12 gallon aluminum gas tank, built 1" angle bar frame around whole tank for sturdy instal, sell $125
MORE STUFF TO COME, lots of BJ FJ land cruiser stuff
Toyotajunky at gblackis@shaw.ca or here:)
