Axle and Ratio questions.
Tulsa, OK
Website
www.cardomain.com
1. Is the 93+ FZJ series running a 4.10?
2. Has anyone had success running an auto locking setup, (Aussie, etc), in the front without a manual hub connversion? No theories please, first hand experience only.
4.10:1
First hand experience, no theory.
Not too many people responding to this. If it is not a trailer queen, then this is not a good idea. My first hand experence is with lockers locked in front on real grippy sandstone. It is a mother to steer. Not safe on the street for a daily driver. later Robbie
I ran a Lockrite in the front of my SAS Toyota truck and I hated every moment of it. I did have hubs, which negated the problem during normal driving, but I use to like to lock the hubs and put in 4WD whenever I hit the dirt roads, or snow or whatever, so I could have the AWD affect while driving around and better control at speed.
It sucked really bad. Even at slow speed, steering was a bitch. And after driving on a few ledge roads, and having the steering respond slower than I espected, I said enough of this....and installed an ARB up front.
It looks like you already have it installed up front. What do you think of it?
I havn't had any probs with it. Snow, dirt, even some dry pavement patches here and there. My old SAS `91 4runner was TRD electric F/R, and you absolutely could not steer when the front was engaged. This is why I was pleasantly suprised with the Aussie on the 60.
I was just wondering what kind of results I might experience with the all-time 4wd/ open center diff configuration.
I had a `91 FJ80 for a mall cruiser way back when, and the 4wd was seemingly transparent with the center diff open.
4:10's in the front. A front locker without manual locking hubs is very hard to steer. It must be a trailer queen. First hand expirience.
I would suspect that they's a difference between the factory locker and an Aussie (or LockRite, Detriot, etc) in the front, regarding steering.
I'm not 100% sure about the factory e-locker, but assuming that it works like the ARB's when locked, they are like a spool, that is allowing no differential action at all between the tires.
The auto lockers (Aussie's, LockRites, Detriot's, etc), on the other hand do allow some differential action between the tires, so I would suspect that's why y'all are experiencing some difference in steering experience.
There's a little more to this than that simply of an explanation, however it's "close 'nough for government work" ;)
Fred
I'm going to try and re-phrase this question.
Does anybody have experience with an auto-locker installed in the front of a full time 4wd vehicle with an open center diff/transfer case? I guess I initially went the long way in describing that portion. Open center is the difference I'm wondering about.
If yes, please elaborate.
Thanks, KR
