Right hand drive?
Looks great. I’m about to powder coat the same wheels. Love the color. How did you handle the lug nuts?(continued)
All in all id rank the fitment 8 of 10. The carpet meeting the middle row seat base doesn't fit flush to the sheet metal, id say about a half inch to an inch of " float" ( picture below ). I may try adding some adhesive backed insulating foam to take up the slack. Interestingly this gap wasn't visible until i bolted down the rear side steps.
My process started with laying the factory pieces on top of the new carpet and tracing the old cutouts with chalk. I also used to the foam cutouts for the rear bench on the new carpet as a reference before committing to cutting the first bolt holes ( front seat rail as described above)
No complaints with the front section, its flush with all the factory sheet metal undulations
These results are due to my mediocre judgement eyeing up the carpet, that being said if i did it over again ( and i may down the line), id have gone with the non mass backed option and laid down monster mat insulation directly to the floor boards. Some of the angles seen on the factory carpet seem a little sharp for the thicker material to track. With my new dove grey factory floor mats it actually looks great, all the nitpicking aside!
Here some other updates / restoration items ive done so far.:
Recovered wheel from Craft Customs. they matched the grain pretty well
GROM Vline LITE mounted below the AHC delete " coin tray" or whatever the hell its supposed to be. Block off plate coming soon. USB routed into the center console
Powder coated wheels and matched center caps ( Prismatic Powders color: heavy steel with a soft clear coat on top. It looks semi gloss)
I didn’t do anything to the lug nuts, the plastic center caps were paint matched by the vendor it’s not a 100% match but close enough for meLooks great. I’m about to powder coat the same wheels. Love the color. How did you handle the lug nuts?
@dnp Wanting to order a set of these if possible.@Tupelo Honey Sent PM
Nice write-up of your process -- thanks for sharing. I'm really happy with the dark (ebony) carpet as well. Good insight on the mass backing too. I also changed my tired/stained speaker covers to a black fabric and it hits nice with the dark carpet too.I didn’t do anything to the lug nuts, the plastic center caps were paint matched by the vendor it’s not a 100% match but close enough for me
I’d like to see the tan too. ThxDoes anyone have photos from a tan install?
Just finished up this weekend. Adding a base plate for my drawers in the rear so i didn't cut holes but you get the idea. The color I ordered was Antelope. Made some bad cuts, but most is covered up beside the front passenger outer seat mount. The areas where the carpet needs to round off like in the second picture below the seat are the hardest areas to make look right and under the front seats. Just take your time on those areas.
Fairly satisfied with the install. The carpet itself is nice and seems as if it will hold up well. Still need to add velcro in the spots that are on the original carpet (footwells & rear cargo transition). These are the only pictures I have after it was finished. Hope it helps!
View attachment 3545060View attachment 3545061View attachment 3545059
That looks great. Did you get the mass loaded vinyl backed carpet? Thanks !Just finished up this weekend. Adding a base plate for my drawers in the rear so i didn't cut holes but you get the idea. The color I ordered was Antelope. Made some bad cuts, but most is covered up beside the front passenger outer seat mount. The areas where the carpet needs to round off like in the second picture below the seat are the hardest areas to make look right and under the front seats. Just take your time on those areas.
Yes that does look very nice. How many hours overall was the install?That looks great. Did you get the mass loaded vinyl backed carpet? Thanks !
You tagged me, not HTXFLY above.Yes that does look very nice. How many hours overall was the install?
oops sorry!You tagged me, not HTXFLY above.
