Since purchasing my 2003 LX 470 last January, I have been researching how to get full time power to my dome lights and power outlets. I have installed a second (auxiliary) battery and a National Luna dual battery system.
There are a couple of threads already written on how easy it is to put all the accessories on full-power for a pre-2003 vehicle. It simply requires a jumper in one of the fuse boxes from the main battery. However, the fuse system was changed on the 2003 models and the fine writeup on the pre-2003 models basically says, "It's a pain in the ass to do this to post 2002 models due to the location of electrical panel.
I spent a lot of time tracking down the wiring system and agree, too get to the panel to jump all the accessories at once is both a pain in the ass to get to and most likely to cause other electrical issues once all the cabling disconnections are made and then reconnected.
So... After literally months of thinking about this, it came to me. Why don't I just jump the individual systems I want on full auxiliary power such as my interior lights and power outlets? I can add a fused positive jumper blade into the OEM fuse box on the "device" side to have power on all the time.
However, if I jump power from the auxiliary battery, the ground will still come from the main battery. Will this cause a problem?
All my other connections to the auxiliary battery are both powered and grounded directly to the auxiliary battery. Need advice on if I can power from Auxiliary and Ground from the frame ( Main Battery.)
Appreciate your help.
